the brakes on my bike are a bit naff... (160mm front and back)
the front disk which came with the bike isn't so bad...
but the disk kit which came with the rear hub motor kit is pretty bad... adjusting it the best I can... by the time the pads aren't catching the disk there's not enough break left... I can pull the break all the way back and it's not stopping me...
so I'm thinking I should upgrade... before I kill myself... it's surprising how much it takes to stop from 20mph which is about my average speed... stopping from 40mph is terrible...
so bigger disks = more leverage = more stopping power
so I could get a pair of THESE so I can take 200mm disks...
but... are all disks about the same ?
and then, is there much difference in different makes of callipers ?
and are hydraulic much better than cable ? - if I go hydraulic then I'll have to mod the leavers to take the switches to cut the power and activate the regen brake.. and then I need to make sure they're the right length for my bike... (and be easy to move, because I'm thinking about getting a different frame)
until a month ago I hadn't been on a bike in 15 years... and a lot has changed since then :-o
