myxomop said:"BigMalectrics" ready
For welding copper with flux, six super capacitors were enough (copper 0.2mm tape + 2mm copper busbar, pulse 10 ms)
Nickel 0.2mm 2ms.
These are the modern names of this alloy:EXAMPLE 1 40 parts by weight of powdered Lag 45 silver solder, consisting of 45 percent Ag, 18 percent Cu, 20 percent Cd and 17 percent Zn; 60 parts by weight of soldering flux containing 50 percent rosin, 38 percent tallow and 12 percent sal ammoniac.
I can not find any modern equivalent of this alloy.EXAMPLE 2 50 parts by weighttof powdered Lag 12 Cd silver solder, consisting of 12 percent Ag, 45 percent-Cu, 7 percent Cd and 36 percent Zn;
50 parts by weight of soldering flux containing 45 percent rosin, 45 percent tallow and 10 percent sal ammoniac.
This is just pure Silver, not an alloy.EXAMPLE 3 25 parts by weight of powdered silver; 75 parts by weight of soldering flux containing, 55 percent rosin, 30 percent tallow and 15 percent sal ammoniac.
Resistance Welding - Lap Weld 0.007" (0,2 mm) Copper Sheet
We used a 3/16” (5 mm) Tungsten electrode with a “rounded” tip. Welds are easily, and quickly performed, with great strength. We used 1AWG (40 mm^2) cables with this hand piece, to ensure we have as much current at the weld site as possible.
Special flux for GuoXuan battery, Copper to copper spot welder, Current is needed 2000 A - 8000 A Above current The higher the current, the better the spot welding effect, Energy storage spot welder 8 About a millisecond Transformer Spot Welder General 60 About a millisecond, When buying flux, please make sure that your machine current can reach such a high current If not, it is impossible to spot weld copper, Please purchase carefully, Flux for disposable items do not accept refund, please see clearly in the purchase, thank you!
Product specifications:Copper flux
