Squad
- Joined
- Jun 28, 2015
- Messages
- 148
whitepony said:ahaha, cool
I read you killed your vesc in the living room (enertion forums or so?). you probably went like full throttle break, repeat. you should check the live monitor of your vesc and watch the voltage. I had a similar problem with a loop key (yet unresolved), where I would induce large spikes against the current flow (full throttle -> voltage sags, full brake -> voltage spikes). i think thats how I killed my vescs, might be useful to check the cable lengths, loops for unnecessary inductances!
Thanks, I'll do more tests when I'll put everything back together, I see my VESCs have just been sent. The VESC and mosfet switch blew up when I changed direction of movement and the board was still going in the other one, after few such changes, no load on board. Even if there was too large inductance, battery cables are as short as they can, there is no way to shorten them. Well I hope I don't f*** up this time
