icecube57
Since Im at the point of finalizing my pack 24s3p 88v 15AH I thought it would be a good idea to protect my packs. The heatshrink was starting to crack on some of the first packs I aqquired. The tape bonding my pack sections was starting too fail. Its time to protect this investment a little bit better. I have tons of peel and stick floor tile. I thought this would be a good workable material to protect my packs.
To prep the packs I discharged them near empty. When I taped them before they were fully charge. As the packs discharge they shrink a bit. This caused the pack to become loose. This time Im taping them near fully discharged and compress them while taping. I removed the old tape and applied 1 1/2 inch clear packing tape to the packs.As I was taping I pulled it really tight to compress the pack. I did 3 rows of tape across the pack. When I was done the 3 packs felt firm and solid.
I then took sheets of paper and traced the pack. One thing i did notice was the packs werent the same height when I taped them together. They were physically different sizes. So Instead of covering the whole pack i left the top 1/4 inch uncover to allow the discharge and balance wires to exit. The main part of the pack is protected and that was the goal.I had to slighly oversize my tracing to make sure they fit the other packs i will do in the future. I will trim the excess when I do the rest of the packs. I copied my templates to the tile. Cut them out and applied it to the pack. It takes a little bit of work. They arent going to line up perfectly but It will be nice and neat if you measured pefectly. Me personally... Im going to make another Identical pack to the one pictured below. Im going to pair them together and finish the pack with Black Gorilla Tape to make two 44v 15Ah sections. I will even make a carrying handle for easy transport. =P They will neatly fit in my rear trunk bag. 12 packs stacked neatly in a trunk. Can be take off for transport. Well protected incase of a wipeout. Range for days.
