So I made this DIY UPS with a 1500w inverter, 4s Winston battery, 15v meanwell PSU and a amp meter configured with a LVC set to 11.5v.
Everything works fine except that there is no recovery voltage on the amp meter, when it hits LVC it won't come back ON unless I press the power button.
I can't use a BMS at the cell level because the battery is sealed.
Does anyone knows a device that I could set a LVC and a Recovery voltage? (Shutdown at 11.5v PowerOn at 13v)
