Lebowski
Minor legend
my controller IC has a hard limiter for the max-erpms, when it goes over this setting it cuts the power. Maybe your controller has something similar ?
Lebowski said:my controller IC has a hard limiter for the max-erpms, when it goes over this setting it cuts the power. Maybe your controller has something similar ?
agreed, mine too, my point is more that the max erpm may be limited by a software setting...querlenker said:Lebowski said:my controller IC has a hard limiter for the max-erpms, when it goes over this setting it cuts the power. Maybe your controller has something similar ?
The Sevcon is able to run this motor above 6k rpm..
John in CR said:Doctorbass said:Problem is that at high speed ( i mean over 90kmh) i get the motor cut out !!!
I hope you meant MPH, not kmh. I was going to challenge you to a podcast race, but if 90kph is "high speed" for you, it simply wouldn't be fair, since I call 90 slightly over half speed.![]()
I hope you get the shut down issue sorted out.
Doctorbass said:John in CR said:Doctorbass said:Problem is that at high speed ( i mean over 90kmh) i get the motor cut out !!!
No.. it's really 90kmh average where it cut... but it can reach about 125-130 for the first 20 minutes no prob..
Also the controller is having wron settings for the field weakening.. it only reach about 4000rpm but it can reach 6000rpm.. i can hear it reaching 6000rpm if i twist the throttle with the wheel off the ground.... but it drop immediatly and oscillate to around 4000rpm.
There is some setting that limit to around 4000rpm...
liveforphysics said:I am excited to see the future of controllers leveraging cutting edge hardware be created with orders of magnitude less restrictive processing and high-speed high accuracy current sampling rates. I am grateful for all the amazing people creating it.
John in CR said:liveforphysics said:I am excited to see the future of controllers leveraging cutting edge hardware be created with orders of magnitude less restrictive processing and high-speed high accuracy current sampling rates. I am grateful for all the amazing people creating it.
Doc is way past regular people, but my attitude is that if regular people can't use the stuff by simply following easy to read instructions, then the item should still be in beta testing. Screw attempts to make stuff expensive for no good reason. Screw attempts to make things so un-userfriendly that they can only be serviced or set up by a factory authorized technician.
Bison_69 said:Hi Doc,
Here you go... SEVCON GEN 4 - Introduction to DVT (see page 6.2)
https://www.thunderstruck-ev.com/images/TS Vehicles 9-7-11/Gen4 Product Manual V3.2.pdf
Also ''Using DVT with Gen4 Systems''
https://www.thunderstruck-ev.com/images/DVT Tutorial.pdf
Bye...
querlenker said:From my experience, I compared Cycle analyst readings with gen4 data logging and there was a big difference.. I do trust more the gen4 and did not manage to draw significant more than the rated boost current.
Doctorbass said:With the old Me0913 motor and the Size 4 controller I remember I measured peak amp of 452A already... Now with the 75-7 and still tuning it I measured peak to 528A !!! on the cycle analyst!.. the max current limit is still set to 420, no change...
I just wonder how the hell can this controller draw 108A more than the max setting?that's 25% overshoot current!
Doc
liveforphysics said:Doctorbass said:With the old Me0913 motor and the Size 4 controller I remember I measured peak amp of 452A already... Now with the 75-7 and still tuning it I measured peak to 528A !!! on the cycle analyst!.. the max current limit is still set to 420, no change...
Doc
You know Ibatt and Iphase are very different right? If your Iphase target was say 420A, your Ibatt can range between ~5A to ~600A, all while holding exactly 420A phase current. Using timing advance and I would assume battery current could grow yet another few hundred amps while Iphase remains 420A.
Doc
