TysonScott said:
text
am wondering if battery chemistry affects the range of the ev
Not at all.. I think chemistry does not affect much the range, but it could depend on output voltage interval window.
Imagine U have a scooter battery 16S lithium ion 67V, and a compatible LiFePO4 maybe 19S to get same voltage interval range.
Even if U use Duracell alkaline cells, but those are 1,5V rated, soo U need around 40S array..
@google source "DURACELL Battery, 1.5 V, AA, Alkaline, 2.85 Ah, Raised Positive and Flat Negative, 14.5 mm"
Some scooters use 5S Pb 12V and could be replaced easy for compatible 16S6P lithium ion (35Kg vs 5Kg for same range, lithium helps veicule to be more stable, more acceleration, faster because removed 30Kg from scooter! a 16S6P 16Ah lithium battery will perform same as 5S Pb sealed 20Ah, both delivery 40Km range aprox, but lithium will last much longer time! price here 400eur for x5Pb and 600eur for a 16S6P 16Ah lithium battery and U could get back refund 30eur from x5 PB used batteries compared to refund a very used lithium scooter battery worth 60eur(half capacity/20Km range), so Pb initial cost would be 370 vs 540eur lithium(including rebate). Does saving money worth?)
Lithium Ion battery will cost half or 1/3 compared to same Wh LiFePo4 battery (including all cells,bms, and charger) for tha same proposes & voltage window (but LiFePO4 more safe, + current peak out, and fast charge ex. A123 10min fast charge).
price compare different chemistry: Alkaline < Pb < Lithium Ion < LiFePo4 < LTO(hybrid cell/capacitor) << super capacitors w/high capacity
chemistry is just the base reactions method to produce energy, but at final results the Ah is what matters at voltage working interval @ some current demand. someone correct me if I'm wrong.
There are many chemistry available even sub categories. for example at li ion cells we have INR, ICR etc. we have also lithium polymer, LTO, plus LiFePO4 and Pb batteries chemistry and many others..
Some types of chemistry keeps the volts at a more high level during use. Some lasts more life time. LTO go many thousands of cycles.
The matter are Ah capacitity output(at some voltage interval window) and internal IR of cells. but chemistry affects battery life cycles and safety and also recycle concerns
What matters if source is a lithium cell or a nuclear cell? once is rated example @20Ah U should get those 20Ah output..but take in consideration working voltages interval of system. means real Wh output at some voltage interval for comparative proposes of different chemistry elements.
just sayin
