Does high rpm or torque kill drive train parts?
Desertprep
United States
I have read many posts on this forum about how to connect very powerful motors to the rear wheel. Invariably I hear of chains breaking or wearing out quickly, gears getting rounded off, etc. Is it the torque from the motors that causes these problems or is it the speed? or a combination of both?
Speed is more of a concern with noise, although bearings getting over-reved can become a consideration.
Indeed, my crank drive endures heavy force which degrades it (gearbox, chains, sprockets, and mounts stress). On the other hand, I am working on friction drive so that I can get away from those high torques but that means some extra consideration has to be given to high RPMs. The advantage I see for friction drive for me might be that the smallish motors I use have to spin fast anyway, so with the drive right at the outer circumference of the wheel, less gearing down is necessary. It's mainly a matter of getting the thing fabricated since friction drive is rare compared to what it used to be and that means less available premade stuff for piecing together.
In a word, YES. LOL!
hmmmmm okkkkkkkk :) To make the rubber meet the road...if using a motor, tranny and chain setup, I am guessing that the chain, the gears and everything else in the rear of the bike will last longer if the motor speed is geared way down (say, to 8 mph speed) in the reduction unit and then sped up with gears in the rear? I am in search of dependability with this question.
There's no reason to gear it down to a really low rpm just to gear it back up.....unless you're driving the crank.
My experience (for what it's worth...) is that chains are fine until you go over 4000revs - then they throw out all the lubricant. For that reason I always use belts for the first stage from an RC outrunner now. For me the belts are more expensive & trickier to set up but, done right, they last.
In general, wear is based on contact force (which relates to torque and distance) and number of cycles (which increases with speed). A smaller diameter/number of teeth sprocket will have larger forces and wear quicker.
Metal fatigue is also based on force and number of cycles. So it is a combination of both.
