Took me two years before I got around to building Bouncing Betty. I just got through working on it some more.
BTW, still bulk charging with either a ping 5 amps charger, or a similar one I got from EM3ev. I never charge higher than 4.15v, giving me a bit of leeway at the top. I was doing 4.1v, but didn't like losing that much range.
The pack I bought last spring stayed balanced pretty good all year. I have taken to mostly just balancing the one cell that needs it. Average time between balancing is about 3 months, but that is only about 15 cycles per month. Retired, I don't go to the grocery every day. But 5 ah of the pack got a very light, like 30% discharge daily. It's no less in need of balancing than the other 10 ah. But the cycles were so light on that pack, it still has not run that many wh.
Bought 14s 10 ah of new Lico, so now I have 25 ah of new, or pretty good lico. Enough to ride 30 mph for 30 miles.
I found that though cool, the motorcycle saddlebags I could find cheap were pretty small in capacity. And then if loaded, they bounced quite a bit. I thought about a few zillon options, from the kitty litter buckets to regular luggage, trash cans, wicker laundry baskets, etc. The best option I could find was some 12" wide 24" long ice chests. But calculations showed little improvement in real capacity. Plus, anything much wider than 10 inches was going to make it turn into a bike that always must take the lane. I really wanted something about 8 inches wide, so that the burble of air from my leg would help lessen the wind drag. Too wide, and the corner is out in the full wind.
Last time I went camping on the bike, it really was pretty tight to carry it all. It's the desert, so the stuff to carry starts with about 3 gallons of water. The load ended up very top heavy, and I still could barely fit a bit of food on the top. I want the load carried lower for starters, and I want room to carry some extra clothes, something to read, perhaps even the laptop for an ES fix while waiting on charging.
So when I dug up some old buried stop signs in my backyard cleanup....
Viola! Super Panniers!
They are 7 inches wide, 30 inches long, and 18 inches deep. The stop sign supports the inner side quite well, and there is much less flop of the panniers than the motorcycle bags. Built into each side, is a battery tray able to hold up to 48v 15 ah of RC lipo battery. So with the battery bag, I can carry all my batteries at once, and still have about 22x18 of free space, plus a corner under the battery where I can tuck the emergency tool kit, or other less often needed items. The outer panel is an old coroplast political sign. But I might go with some wood panel later for the woody look. Depends on if the coroplast breaks down in use too fast or not. I like the lightness of the coroplast. The aluminum sign and the wood are heavy enough as it is. But heavy as it is, few things will be as light, in that size.
The top is finished off covered with some old coated canvas, that used to be a balloon basket cover. Still need to do some sewing to complete that.
This is going to work great, now all the heaviest camping gear, food and water carry right at axle level, with the top entirely free to carry just the tent, sleeping bag, and pads.
