Didn't Hyena say his could be changed by altering a file on the card (or in it's internal memory, I forget which)? But that it overwrote taht file and reset to default each time it was power cycled?
Yeah, but change won't last. I've got some vids w proper date but it resets at startup? Very tricky to operate, aim etc, but light as air. Easy to clip to anything...amberwolf said:Didn't Hyena say his could be changed by altering a file on the card (or in it's internal memory, I forget which)? But that it overwrote taht file and reset to default each time it was power cycled?
That was certainly true on CrazyBike2--when I moved the 45lbs of SLA to the center triangle from the rear just in front of and below the axles, even though it was slightly higher in the center it was still much easier to maneuver, tilt, etc, and then recover afterwards.The Mighty Volt said:nothing beats having the weight in the middle.
a tail smoothing effect would be what you want to create in a low pressure situation but it would be hard to do considering you'll have to be moving(sometimes in a tuck others sitting upright) so unless it was form fitting and had minimal air leaking into it, it would create the opposite effect and actual slow you down. Either way if you do decide to make a smooth tail you should put a small hole at the end of it to allow an escape for any air that does flow in.amberwolf said:I would venture to say that putting a tailpiece on that smooths the airflow coming off your back and stuff would make more difference than a front fairing. But having never experimented directly with it, I might be wrong. I've seen all sorts of vehicle shapes for air, water, land, with all sorts of front ends, including some that couldn't really be all that aero, but a nearly universal constant is the tail smoothing out to the back.
maydaverave said:Lycra would probably do more good than a fairing 8) :lol:
