CGameProgrammer
Attached is a diagram I've seen posted a few times here on how to wire up a contactor/relay to control power to the controller. I'm using the Tyco EV200 contactor which eliminates back EMF so I'm pretty sure I don't need the diode, but I don't know how to supply the correct voltage to the coil. The coil is rated for 9-36VDC with 12-24V being preferable. It uses 0.13A at 12V or 0.07A at 24V to hold the contacts closed, with a maximum inrush current of 3.8A (for 0.13 seconds) when initially closing them.
Anyway I'd be running either 20s or 30s A123s so have an operating range of theoretically 60-110V. I'd prefer not to draw only from certain battery cells since I like to keep things balanced and have no BMS for discharge. What's the best way to supply power to the coil?
