Solcar
Making a new input shaft for my gearbox, I have to drill perpendicular holes for pins to lock the gears or cogs in place. Anyone have a trick or two to get good holes reliably?
Solcar said:Making a new input shaft for my gearbox, I have to drill perpendicular holes for pins to lock the gears or cogs in place. Anyone have a trick or two to get good holes reliably?
Solcar said:That springloaded punch seems really effective. My guess is that the user cocks it then can get really close eyes on the work piece to get it right on the mark, and the press a release. Now that should get it close. Safety glasses highly recommended.
Solcar said:Thanks for describing that methodology, Gordo. I must be really untalented as a machinist because my holes never are close enough in the block jig approach. That is, my bock type jig had holes that were off by too much. You need a drill press to make the jig.
I wish I were a machinist by trade in this regard, then I would be able to justify having more than simple hand tools. Since my specialty is analog electronics my shop is already full of things needed for that. My bro-in-law gave me a drill press, but it was too sloppy and loose to work at all.Take a close look at the drill press. Maybe you just need to replace the bearings or if the spindle is worn, wrap some shim stock around it?
mat h physics said:If this is a single hole, I'd suggest seeing if the local machine shop will punch it for $10. Having had a $40 drill press from HF for a while I take it for granite. Bought small center dill to drill holes at an angle.
Small drills bits require high speeds, so they won't break. A lager center drill bit may work on a hand drill, but you are looking a small carter key hole. Expect to break drill bits smaller than 1/8" in a hand drill.
PS DO NOT USE diamond/carbide, on steel. Once high temps are achieved, the carbon will literally absorb into the steel (chemically).
