Chuckles1
I have two UPP 48V 20Ah triangle batteries, both the same model, both with identical 2.5A chargers. I'd like to wire them in parallel for extended range in the simplest, safest manner to power my 48V Bafang rear hub drive bike with the stock controller. Chargers use XTR connectors, if memory serves. Current battery to controller connectors are Anderson powerpoles.
I gather that it may be as simple as buying a Y splitter like ebikes.ca offers for $20. I understand that both batteries should be at the same voltage when the connections are made.
1) Is that all there is to it?
2) How would I best charge the batteries once they are wired in parallel? One charger on either battery, doesn't matter which one? Both chargers at once?
I'd like to avoid any unplugging of the Anderson connectors once they are wired in parallel, as they are very secure but a PITA to plug in when I haven't done it for a while.
