Hi again,
I would really love the LMX64, but without a derailleur (to each their own, don’t shoot me
While my ideal gearbox solution would be a Pinion C1.9XR to get the range with less gears, and centered weight distribution, this would require major surgery on the frame, and poses a problem with the torque sensor. I don’t know if any solution other than the Bottom bracket one currently used could be implemented…
As an alternative, I am trying to see if I could adapt a Kindernay IGH to the LMX64 rear wheel, knowing I would probably have to give up the Motor freewheel for fabrication simplicity (unless LMX would have the time and will to offer customization services).
I extrapolated a drawing of the existing Hub from the LMX part picture (below), but I really need to confirm some dimensions, so I can see if an adapter for the kindernay is remotely feasible. Brian was kind enough to already volunteer the chainlines.
I appreciate if anyone can contribute / confirm any of the dimensions in the drawing below.
• Is wheel centered in the 170mm dropout?
• Space between the Motor sprocket and the disc (face to face, and ideally the belt sprocket, but you can confirm the chain sprocket too).
• Thickness of the Motor sprocket (ideally the belt one, but you can confirm the chain sprocket too).
• Space between the outside of the disc and the end of the dropout.
• Caliper extension between disc and sprocket
• Sprocket inside radius / diameter
• Confirm Chainlines
Thank you in advance for any help with this.
