Sab3r Electrics said:
Say hello to your newest member, very pleased to announce that i have just purchased a phasor frame today and im eagerly awaiting its arrival
. I have decided to run a Crystalyte Crown motor with this frame what is everyones opinion on this decision?
a couple of points NOT from an expert:
1) although the crown body is very wide,the stator is NOT as wide as the body would make you believe....the stator (the inside part which would normally be the rotor on a non hub motor) is about as wide as a 4065 or 4080 crystalyte motor although it DOES have more copper (22 pounds versus 16 pounds) and thicker lead wires...
2)HPC had one or two crown motors they were playing with but started having problems at higher voltages not sure what the problems were they are selling their remaining crown motor on ebay they have decided instead to go with a 4065 wound specifically for 100+ volts for their new revolution bike they have told me
3)I have an older vented 4065 motor that was not designed for 100 + volts and have used from 50 to 119 volts on it and in the process burned up the heat sensor,a 90 volt battery pack,and 3 or 4 controllers BUT the motor still works good....the fastest I have gone was 53 mph on my 90 volt system that came fresh off the charger at 100 volts....my batteries are in parallel now until HPC gets a controller that can handle my voltage in series (118 hot off the charger) right now running at 58-59 hot off the charger top speed is 40 mph with pedaling but can cruise easily at 35 mph for many miles
