xyster said:Stevil_Knevil said:I would trade 100 Randy's for 1 Xyster!
-S
So conversely, 1 Xyster = about 100 Randy's ?
Crap, I had no idea I was THAT annoying!
:lol:Beagle123 said:I don't plan to use blinkers (they just helps people run you over).
Lowell said:If everyone agreed, there would be no worthwhile discussion going on.
safe said:The fact of the matter is the spreadsheets are correct and until an error... a "true" error which makes the results incorrect "materializes"... I will maintain that I've produced a nice little "tool".
Hey, it's more than anyone else has done here...
DanEL said:
safe said:Lowell said:100% operational duty cycle, as in the motor could run at that power level forever without burning up since there is never more heat created than the housing can dissipate.
That's not a standard usage for "duty cycle". Normally duty cycle is supposed to mean the percentage of time that a PWM controller is in the "open" state. When the gate is open a lot you have a high percentage of the voltage passing through to the motor and it's said that you have a high percentage duty cycle number. In a hyper-simplified simulation with a fixed gear they are more or less related, but not on a geared bike.
The way you are using "duty cycle" you're thinking in terms of what percentage of time that "in operation" the rpms are at peak power or some other rpm. So you're creating a source of potential confusion. :?
What is the real name of the "operational duty cycle" if that phrase is incorrect?
Anyone?
If you could invent a bike that ran on ego, you would set the land speed record.
safe said:Brushless motors are not the same as brushed motors it seems...
Stevil Knevil said:It's a thin line between clever and stupid, and I plowed right across it
Motors on bicycles are for straight-up cheaters.
.........................."You know making a nuisance in your own neighborhood is a bad idea... you don't want to foul your own nest." (actual paraphrase)
Correct.xyster said:I liked the oxymoron-ish "(actual paraphrase)" part -- I suppose that's like a verbatim paraphrase?
kisshu said:i bought a $89 mongoose gmx aluminum from walmart with shimano components a few years ago and its still working great. the frame is too small but at that price i was willing to sacrifice until i found something that suited me better.
a girl could easily spend 1000 dollars on a designer bikini or more on a dress but they function the same and i could put her in some $200 clothes that would make her just as hot and you could have more fun without woring about stains
xyster said:And the most bizarre analogy award goes to...
