dh-paule said:
Dlogic said:
If you have a total flat on the rear wheel and can´t fix it on the spot, pushing the bike home is a bad idea. Even a single kilometer is total torture.
-----Ride on!! Yeah!!-----
did that for 8km
1.5 hours and 2liters of water needed to arrive
lessons learned:
go for mx tyre and mousse = no more flat
I was intrigued by your avatar pic and have to ask:
Do you run stock phase and hall connectors between the motor and ESC?
Any extra seals on the controllers cables going out of the bottom?
Are you running some kind of mud guard on rear shock?
That picture looks like a pretty caked up bomber
Whenever I dip in some deeper water, the hall sensor gets wet and I have to dry it off to fix the stuttering.
It happens even though there is a ton of dielectric grease stuffed in the connector.
Marek
