Theodore Voltaire said:Allex said:TV, thanx, that's just another hub motor, I would like to try out a mid drive.
I don't get the point of mid drive Allex. It's so last century. For a motorcycle I can understand if you're going to have 50 hp, but for a bicycle fuhgetaboudit. Why go from no maintenance, to high maintenance, and noisy? And shifting gears? What a waste of time, unless you're climbing Pikes Peak everyday.
But if you must, I recommend you get belt drive. At least that'll make it a little quieter, and cut down on the maintenance.
TV about hub motors….For general transpo, prob true but for more extreme riding/ racing or off road riding if there was a mid drive w equal or even close to equal power it would take a hub drive any day.
1. The ability to select gears and keep the motor at the correct speed regardless of rear wheel speed.
2. possibly even more important is sprung weight. That friggin brick of a motor on the rear wheel really screws with handling and makes tuning suspension a huge comprmise.
Also it can be downright dangerous. Accidentally hitting a deep washout or a curb at speed with the heavy motor in the rear wheel can cause broken spokes or a broken rim.
3. The front end won't push so bad because of the weight balance.
4. Overheating the motor because its not at the correct RPM range is not an issue.
5. Water crossings are not as big of a deal because the motor is higher in the frame.
