1abv said:Hey does anyone have a line on parts for the Vboxx? Before going into it I wanted to see if anyone knows where to get stuff from. Its out of the 2 year warranty at this point.
thanks fellas.
Justtoby said:1abv said:Hey does anyone have a line on parts for the Vboxx? Before going into it I wanted to see if anyone knows where to get stuff from. Its out of the 2 year warranty at this point.
thanks fellas.
I think you can buy direct from Suntour and I expect dlogic on here has contacts. I don't think a lot goes wrong that needs replacing, more a service and reset
1abv said:Tried to contact suntour no luck.too bad stealth doesn't have a base in the US...
Samd said:Anyone had to put a mxus v3 into a recent bomber that has the new style display?
I am thinking the temp sensor would need to be switched and the phase wires sorted in order to match the new bomber lcd display?
Possibly easier to fit a better sine wave controller and cav3 and remove the old display but a bit of surgery if so.
Thanks Rix. I assume its a standard 10k thermistor in the latest clytes but am not sure.Rix said:Samd said:Anyone had to put a mxus v3 into a recent bomber that has the new style display?
Adding to what you said Sam, either change the temp sensor or the DC1 has to be flashed for the different heat sensor. I ran into this issue when I ran the TC3065 on my Fighter and disconnected my temp sensor wire to get it to work. That said, the older DC1 didn't need the thermo sensor wire connected to get full power, the newer DC1 does (from late 2014-early 2015 and on). If the new motor isn't set up for the DC1 to read temps correctly, the DC1 will default power to 1500watts. And unplugging the DC1 temp sensor wire will also default it to 1500watts. For what its worth.
I was stuffing around in the backyard when I stalled the bike at full WOT for way longer than I should have...result: One fried Adaptto Mini-E
1abv said:Hey all,
so fun updates…I got a flat today weeeee!! on the back of the bike super weeeee!!! side of the tube had a small tear in it. I think i can comfortably say 8 lbs of pressure MAY be too low![]()
on another note while I was changing the tube i noticed that after truing the wheel again I noticed that the spoke ends were sticking too far out so may be a good idea to check em after truing..
Yah Allex builds great packs. You have a 21s battery. It will rip.Justtoby said:I reported back a while ago that mu 72v battery failed. I ordered a new one from Allex and it arrived 2 days after he posted it. It is 30q and runs 88.8v hot off the charger. The battery is smaller and lighter than original and should give more AH too.
The bike feels much more lively without anywhere near as much voltage sag. I have the high torque motor so it was always good for wheelies but now If I give it WOT from pull away the bike will lift the wheel and try to flip without any pulling on the bars and without pedalling. There was enough power to keep the wheel in the air with 3rd gear and I was able to lift the wheel at speed in highest gear.
Very pleased, well packaged, good communications and fast service. Thanks Allex!
1abv said:Hey all,
Rix said:Yah Allex builds great packs. You have a 21s battery. It will rip.Justtoby said:I reported back a while ago that mu 72v battery failed. I ordered a new one from Allex and it arrived 2 days after he posted it. It is 30q and runs 88.8v hot off the charger. The battery is smaller and lighter than original and should give more AH too.
On another note, here is a Stealth Greatest Hits video. Very nicely edited and fun to watch.
[youtube]apAnfJmKaYI[/youtube]
As you noted, even with a 2.5 kWh battery (long overdue in stealthst35326 said:Time for Stealth to jam a 2.5KWH (I think its doable) into that sucker.
Perhaps I should start a new topic.
