Rix
100 TW
Hey CD, hats off to you, you are building on hell of a battery there. I hope its good and no duds as replacing a cell will be a royal PITA.
JtHaas said:Sending prayers for no dud cells!
Also Rix, your phone is looking good :lol: I hope the camera got a little better!
Eye candyCowardlyduck said:And I'm pleased to say, it's a perfect fit.
JtHaas said:Eye candyCowardlyduck said:And I'm pleased to say, it's a perfect fit.
That fits amazing in there. Really great work you did there CD I'm envious
What motor/watts are you planning on running with that big thing? Sorry if that question has been asked a hundred times!
I swap between a '1500W' Leaf motor and a HS4080, both of which have internally mounted fans, vent holes, and heat sinks all around the outside of the magnet ring. Check this thread for all the details:JtHaas said:What motor/watts are you planning on running with that big thing? Sorry if that question has been asked a hundred times!
so a lower top end keeps me a lot more sensible.
Cowardlyduck said:Well I couldn't resist. Even though I still don't have a chain/rear derailleur mounted, I took the new battery out for a spin tonight as the sun was setting.
Cowardlyduck said:With no pedalling, I was hitting the new battery pack hard, drawing 6.5KW. My Boost mode amps limit is currently 115A which means it was giving me 115A at 56.5V. That's insane! The full charge voltage of this pack is 58.8, but I had not even fully charged it before this ride, so it was sagging less than 2V at 115A!
My Adaptto could be overshooting the amps limit for a moment also, which is entirely possible. I know the CA does this also, so my assumptions above could be wrong, but even if they are...my average battery voltage being 52.1 means each cell was at 3.72V average for a 49.1Wh/km ride which is pretty hard going so that is certainly promising.
Oh and in case your wondering...I did hit 85Kph, but that was with a quick test of OVS 3 set on my Adaptto. The normal max speed with this battery and my 5T Leaf motor is about 65Kph which I'm more than happy with most of the time.
Cheers
I didn't do that yet actually...still need to.bigbore said:Did you reset battery cycles to zero? I was thinking of doing it with a new battery and I don't know if is possible without setting also tot km to zero?
I didn't make a video of the battery build (there are plenty out there just like this), but I will try and do another ride video in the next few months.JumperJackFlash said:CD,
Post a video for us please.
