Chalo
100 TW
Go to goodwill or a thrift store and find a baby crockpot, see them all the time, no idea what they are for,
Fondue was a thing in the old days.
Yeah, I know.
Induction cooktop?Had a out side gas burner but it's gone will need to figure out hot to heat the wax now.
Have one of them, like it guess I can use it or buy another.Induction cooktop?
Yea, it gets real hot here. I have an old crock pot just the pot. Paint it black and put some wax in there and see what happens. Zero energy.I occasionally use a thriftstore-find crockpot to melt broken rubber handgrips, wristrests, etc., and recast those by pouring it into plaster molds.
I use a different bigger one to slow-cook chili, or stew, etc. I don't usually have to plug it in for that--at least in summer, just putting the crock part out in the sun inside a black-painted styrofoam cooler with an open top, and glass lid on the crockpot and the cooler is enough to cook it over the hours of daylight.
A lot of things were gross in the late 70's and early 80's, spent 17yrs out there.Now that is effing gross, at least on the road. Thin wicking lube, applied to the whole chain and then wiped off the outside as much as possible, is how bike chains get oiled.
On a related note (related to 90wt oil on chains), there are a number of "wet conditions" bicycle chain lubes out there that are a sticky disgusting mess if you make the mistake of using them. Anything gooey or tacky not only makes your chain into a crap magnet, but it probably doesn't even consistently wick all the way into the pins and bushings where it's needed.A lot of things were gross in the late 70's and early 80's, spent 17yrs out there.
I'm sure things are distorted but for under $15 you get a pot that will wax a chain. After all, there are dozens of sellers and Ebay would have tossed them long ago if they didn't deliver. The buyer has the advantage on Ebay.Nothing about that ad is likely true
Question for those who are removing their chains to rewax:
Do you reuse the quick links?
Have a supply of spare quick links?
Oh I looked it up and it surely seems quite nice indeed, but importing it to Europe makes it unfortunately really expensive..My favorite such lube is a bio-based, radically penetrating oil called Superzilla
I just reuse them, never had one break. I think quick links are made much like chains, any name brand will be built to the industry standard which I guess for chains is 8000N which is kinda weird because you look at tests and you expect super heavy chains to be way stronger and they end up being only a little stronger than a super thin 11 speed or something. They just use steel strong enough for the application, no need to make a 6 speed chain from the same high strength steel as the 12 speed unless it's a special cargo bike chain or something designed to exceed the industry standard.Question for those who are removing their chains to rewax:
My waxing days were in the 80s, before quick links were a thing. Driving the pins out and in was a major PIA of the process.
^-- i love those, i've been experimenting with mid drives and all sorts of different ratios and chain length, i have some of these that are both high mileage in terms of riding and also high mileages in terms of connections/disconnections. And they just keep working.
money, style?Here's an off kilter thought - why don't bikes have dust shields anymore?
On my 43 lb Raleigh TSDZ2 mid drive , 30w of motor assist will move me and bike along at around 9 mph on the flats. 90w probably around 12 to 15 mph.With the chain in a totally average state of lubrication..
No load watts with no chain is 60w, connected to the chain it's 90w.
I would imagine that this 30w of friction climbs under load.. but i don't have a bike trainer or DD hub motor to test that.
How long does that take you from start to finish including prep?I don't get the wax is lot more work argument. It's super easy to pull the chain drop it in a pot of wax even you do this every 100 miles not a big deal.
