DunkenKBliths said:Looks like after around 48,000 KMS my seat decided to crack and break...
Then lost 2 bots... sounded like someone had a go at shooting me...
Luckily Stealth is honoring its Lifetime warranty on the frame....
Back to the factory for a fix-up !
DunkenKBliths said:... think I have changed the tires (crazy Bobs)
about 5 times and the brake pads about the same....
Overall the bike is in pretty good order...
That is a neat classic look with the brown brooks saddle and handlebars. Nice.fluid2150 said:Finally finished my baby. Went for ride to work and back 40km round Tripp. Brakes where rubbing so readjust, better but still a little bit.
Think I'm done modding now crusing
DunkenKBliths said:Ah good idea with a bar to spread the stress...will look at doing this when i get it...
Apart from a new battery at about 30,000kms, I have to re-solder the Hall sensor plug...
everything has held up well for 48,000kms ... think I have changed the tires (crazy Bobs)
Theodore Voltaire said:This worked pretty good for lubing my VBoxx. At the auto supply store I found an assortment of rubber nipples, and caps for vacuum lines. I drilled a hole in the grease tubes cap, and screwed it down on this rubber nipple. The end is small enough to stick in the lube ports in the VBoxx. Didn't make any mess this time.
Theodore Voltaire said:How's this grab you?
Allex said:Theodore Voltaire said:How's this grab you?
I dont get this style TV, you building a classic cruiser but use a modern bike seat.
Look at fluid2150, the Brooks is the way to go.
Rix said:Its not all about spring rate, shock compression valving can affect how much spring weight is needed. I had one shock with a 550# spring that felt stiffer than the shock that came on my Fighter wich was a 750 pound spring. Bike looks tits man. Glad to see you back on the thread.
Theodore Voltaire said:DunkenKBliths said:... think I have changed the tires (crazy Bobs)
What are you, some kind of stinkin street rider?![]()
Theodore Voltaire said:Rix said:Its not all about spring rate, shock compression valving can affect how much spring weight is needed. I had one shock with a 550# spring that felt stiffer than the shock that came on my Fighter wich was a 750 pound spring. Bike looks tits man. Glad to see you back on the thread.
It took me a while to snap to what you're saying Rix. That would explain this shock. It feels like it has little compression damping, but it has a heavy spring, and a lot of rebound damping. So far I've only sampled it while pedaling without power. It feels pretty good at low speed, but the jury is still out. For $100 though, it gives me a chance to see how the length works, and that seems pretty good. I didn't want to spend $500 for an Olins, and find out it was too short to work.
