So no shit, there I was, bleeding my brakes on the Fighter. After my latest vid and ride with Dad, my brakes, especially the rear were feeling spongy and the lever travel was going clear to the hand grip. Did the front first, was easy. Bled the brake in 10 minutes and it works and works perfectly. The rear, well, going to share this, even though I am calling myself out as a short yellow bus riding retard :? . From 2-5 pm on Monday I had fussed with the rear brake only to have it feel very spongy and not work. On Tuesday, another 3 hours, and still felt spongy like I had air bubbles in the line. Wednesday, and for the 20th time, I attempted to bleed the brakes, and they just felt spongy, lever going clear to the handle bar. Friday, came home on lunch, and still couldn't get the damn brake to work for shit. Keep in mind, I know how to bleed brakes and have been doing it periodically on all my motorcycles and vehicles since the 80s. Could not figure out what the problem was with my rear brake on my Fighter. I even ground off 3mm on my magura transfer device which Voice Coils had sent me. Nothing was working. I just knew I had air in the system. I was even contemplating putting heat shrink around the brake line ends where they connected to the lever and caliper, just because I was pissed off and racking my head trying to get this solved. The whole time, I was cussing a storm up, at this point spending about 13-14 hours trying to un fuq my rear brake. I was close to emailing Magura and asking them WTF. Well today, Saturday, 6 days later and about 15-16hours, I saw it. I saw what the problem was. Just a tiny bit of movement on the plunger screw. On the lever, there is a little star key (Torx) plunger screw, its what pushes on the master cylinder plunger that pushes the fluid to the caliper which actuates the brakes. That little tiny MOFO screw was loose and backed out a little it. So, I tightened that up, bled the brakes, and presto, they work and work very very well. In fact, they are more sensitive then the front because I had shimmed 3mm off my transfer device. Anyway, I shared this because if save someone else 16 hours of trouble by checking the brake lever plunger screw, its worth it, even at the price of me looking like a tard.
