Allex
I think they use some kind of li-ion, perhaps even 18650cells?
Somebody need to crack that battery up!
bigbore said:You're right .... I'm loving this rear motocross tyre![]()
I'm currently using the bike for daily commute to work (16Km total) and I have not noticed a lot of wear yet. Some times ago with Halo Contra at the rear I noticed a very fast wear on road.
1abv said:![]()
"you see what happens Larry?? You see what happens when you F@!q$# a stranger in the a@@???"
hmmm my bike wont charge.....could be anything really...... I got XLR-ed.....Thankfully it was the cheapest of the fixes...
bigbore said:A beautiful morning trip at the beach:
Rix said:Very nice Simone, Come ti trovi la rota MC?
bigbore said:Rix said:Very nice Simone, Come ti trovi la rota MC?
Mi ci trovo benissimo! E' una bomba!![]()
Rix said:bigbore said:Rix said:Very nice Simone, Come ti trovi la rota MC?
Sono felice!!! Non e ancora trovato qualche uno quella cambiato alla rota MC ritorni alla rota MTB. Better get back to English. I am glad you like the MC rear wheel and find it to be the bomb. Even though there is a slight weight penalty, in 3 years, I have only flatted the MC once, and that was riding through a construction site and I picked up a nail.
="bigboreSono felice!!! Non e ancora trovato qualche uno quella cambiato alla rota MC ritorni alla rota MTB. Better get back to English. I am glad you like the MC rear wheel and find it to be the bomb. Even though there is a slight weight penalty, in 3 years, I have only flatted the MC once, and that was riding through a construction site and I picked up a nail.
Grande!
Tell me your best advice about which pressure should I inflate the rear MC tyre.
I rode for the first week with a rear tyre pressure of 15PSI (very good on the sand and lose stuff) but last ride I hit the edge of a sidewalk and seemed to me that the rim touched the edge of the sidewalk at speed of about 20Km/h, nothing broke but I had the impression that the rear tube could be pinch flatted if I keep doing things like that. So yesterday I increased the rear pressure at 17,5PSI and I'm going to try the rear tyre that way
Rix said:Anyway, I shared this because if save someone else 16 hours of trouble by checking the brake lever plunger screw, its worth it, even at the price of me looking like a tard.![]()
voicecoils said:Rix said:Anyway, I shared this because if save someone else 16 hours of trouble by checking the brake lever plunger screw, its worth it, even at the price of me looking like a tard.![]()
Ouch that is a touch lesson.
Yep, backing out the lever adjust all the way is a necessary pre-bleed step, otherwise you have preload on the plunger and can't fully fill the system with enough fluid.
Hey sundrive, just a thought does the fighter have a crystalite controller. There's a chance there is a alternative solder pads on the board for brake hi or brake low. Might be just a case of swapping your brake wires. I think maybe ebikes ca might be able to help if you shoot em a email as they sell xlyte controllersSUNDRIVE said:Thanks Brute,
So I would need to run a separate 12V supply throught the microswitch and relay coil, I will have to check if the Domino microswitch can handle 12V. Now as far as getting the 12V supply from the Stealth Fighter, can anyone direct me to the right wires ? My search skills are rubbish, but I did try searching this topic for "Stealth wiring diagram", surely within 484 pages someone has posted one, but I could not find one, does anyone know if a stealth wiring diagram is buried in the topic, or elsewhere in the forum, or somewhere else ?? I am sure others would find this useful too.
JB
I don`t know how much current you would be drawing but I think a 24V relay would handle 48+volts at low current ok ,less than 15 amps ?SUNDRIVE said:Thanks Brute,
JB
