Rix
100 TW
Yah Paule, thats what I was thinging, super motard racing. Sweet.
QuestionMan said:Stealth Rider, great write up on the tires. I am looking to purchase the 19" prowheel with the shinko 241 tire for a torque raptor build. Do you think the shinko 241 really helps with pinch flats? I'll tell you, I've yet to get a normal flat just pinch flats. Even by inflating my 26" bike tire to 60 PSI before a ride I still got a pinch flat. Having to push the bike home over 5 miles was no fun either.
Are you running a prowheel up front? If not, why?
What PSI do you use on the shinko 241, and if you use 35PSI is that enough to avoid pinch flats when hitting curbs really fast?
pendragon8000 said:at the bottom
The bike after insall![]()
http://www.ebay.com.au/itm/48V1500W-e-bike-electric-bicycle-conversion-kit-with-48V20AH-LIFEPO4-battery-/130991608386?ssPageName=ADME:B:SS:AU:1120
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!
HAHA
QuestionMan said:What PSI do you use on the shinko 241, and if you use 35PSI is that enough to avoid pinch flats when hitting curbs really fast?
I'm running 35 psi in the Heidenau K35 but I'll try dropping it a bit as Rix has lots of good exerience with the ProWheel setup.
4Wude said:Rix claims the 17x1.4 is the best rim option on a stealth fighter....but then hyena says his rims are 1.6. which truly are the best, and where could I buy them and have them installed in the sydney region? can I still use my razor tyres that came with the bike or would it be best to upgrade to moto tyres as well? and do i get mousse?
well said Sir.Kepler said:4Wude said:Rix claims the 17x1.4 is the best rim option on a stealth fighter....but then hyena says his rims are 1.6. which truly are the best, and where could I buy them and have them installed in the sydney region? can I still use my razor tyres that came with the bike or would it be best to upgrade to moto tyres as well? and do i get mousse?
Rix is not claiming anything. He is merely offering his well respected opinion. You need to make your own choice.
tires are the big question, the tires just do not wear very fast on the front so you could get away with using a bicycle knobby on the front and it will last. You also do not need a stronger rim because it hardly takes any abuse.
litespeed said:The haters are always there! Find anything in life that brings you joy and someone WILL oppose it! How's that for a pessimistic Tuesday morning quote!
Tom
wugambino said:I didn't know there were so many haters out there...
http://forums.mtbr.com/general-discussion/electric-bikes-mtb-trails-809098.html
wugambino said:Curious.... about how many stealth bikes are in the States?
I don't think a single one of them has ridden an e-bike or been on a ride with another e-biker.wugambino said:I didn't know there were so many haters out there...
Rix said:As far as Stealth Ebikers go, got to be at least 40 between the Fighter and Bomber in the lower 48s. Of course that doesn't equate to one bike per state.....yet. I also think my estimate is on the low side. Could be closer to 60 and increasing weekly.
