ktronik
Hey,
getting the hang of the RC stuff...SM is learning me up, thanks mate, here's some back at ya...
and after looking at a few BEC outputs, I though, now that is perfect for powering a AMC7135 LDO reg for the CC drving of LEDs... in English, its a chip that will drive 350mA of constant current, (needed for LEDs) and very is cheap and easy to get...wack em in parallel and you can stack up as many as you like, to build more or less light out the front or back
So you build a 'blinder' out of a 'rail' shaped piece of alloy, wack a few clear bits on front and side and you have a LED waterproof light housing
http://endless-sphere.com/forums/viewtopic.php?f=2&t=13479&hilit=blinder
http://www.candlepowerforums.com/vb/showthread.php?t=194266
So make what ever LED light you need,(ask for directions here) buy some DX AMC7135 (a less than $3) drivers to hook to your red or white LEDs, and power them from your BEC, 5v output, no more DC_DC converter from main pack, as you allready got one, with your RC system!!
easy to get 800lm from 3 LEDs with med drive level..use the 10 deg optics, (can link) and you got a good bright spoty...
enjoy
Ktronik
enjoy
Ktronik
