unclejemima
Here the scoop. I have a plug with 4 pins in it. I know 2 of the pins are positive, and 2 of the pins are negative. Only problem, i don't know which ones.
...so, how I used to do it was use a automotive test light. Hook one end up to a battery negative post and then start probing the wires till the light on the tester lit up.
This worked great on 12v stuff, but on my 48v battery (what I'm working on now) it did not work so good. Blew the test light in about 1/10 of a second!
What easy way can I test to see what pins are positive and what pins are negative with just a regular multi-meter? I was thinking of hooking one end of the meter up to a battery (12v battery) negative post...then start probing the pins one at a time until I got a reading. Would that work?
Any advice would be appreciated!
