In Ontario/Canada, the definition of an ebike is...
-Has a maximum weight of 120 kg (includes the weight of bike and battery);
-Has wheels with a diameter of at least 350 mm and width of at least 35 mm; and
-Meets the federal definition of a power-assisted bicycle:
-has steering handlebars and is equipped with pedals,
-is designed to travel on not more than three wheels in contact with the ground,
-is capable of being propelled by muscular power,
-has one or more electric motors that have, singly or in combination, the following characteristics:
-it has a total continuous power output rating, measured at the shaft of each motor, of 500 W or less,
-if it is engaged by the use of muscular power, power assistance immediately ceases when the muscular power ceases,
-if it is engaged by the use of an accelerator controller, power assistance immediately ceases when the brakes are applied, and
-it is incapable of providing further assistance when the bicycle attains a speed of 32 km/h on level ground,
-bears a label that is permanently affixed by the manufacturer and appears in a conspicuous location stating, in both official
languages, that the vehicle is a power-assisted bicycle as defined federally, and
-has one of the following safety features,
-an enabling mechanism to turn the electric motor on and off that is separate from the accelerator controller
and fitted in such a manner that it is operable by the driver, or
-a mechanism that prevents the motor from being engaged before the bicycle attains 3 km/hr.
So what if your bike does not comply with the definition eg. suppose you not have the label indicating the ebike meets regulation? Does that mean it is not considered an ebike? If not an ebike, does it automatically become a motorized vehicle ie. a moped, requiring a license plate and insurance? The penalty for driving a motorized vehicle without insurance is a minimum $6250 fine for a first offense, $12500 for a second offense. If you are pulled-over and the cop dislikes you for any reason, would you be facing heavy fines if your bike did not comply with the ebike definition "exactly"?
What happens if you are building your own DIY ebike? Even if you intend to comply with the power and speed limitations, how do you get the required label? I have not heard there are test facilities where you can bring a DIY bike to get the label. Does that mean DIY ebikes are not legally permitted under any circumstances?
