doc007 said:
Snowchyld, thanks for the info!! It's a lot clearer now. I think I will use your method of wiring since I do intend to bulk charge. Also, there is less of a wiring mess.
Questions:
1) When I wire up the batteries like you have in your drawing, do I need to worry about the order in which I connect them? I was thinking of making a block of bullet connectors that plug into each side of the pack(20s1p) at the same time.
2) Also, do you think I will have to worry about a spark when plugging them into the controller or the charger?
Thanks a bunch for all the help!
1.
if you mean what wires go where, then absolutely. yes.
the actual order in which you connect the main packs by their discharge leads doesn't really matter much (more at the end), but once this is done, you need to be extremely careful when connecting each individual pack's balance wires from one 20s 5ah string to its 'sister' pack in the other string of 20s5ah. if for example you connect pack 1's balance leads in string 1 to pack 3's balance leads in string 2, then you'll get a nice big flash, and you wont have any more balance leads on pack 3. There's a number of other dangers that exist, but rather than list them all, I'll simply say this...
Once you have each separate 20s 5ah 'subpack' wired up in series (via the main discharge leads) go through and label with a bit of masking tape or something, each packs #, counting up from the most -ve pack in each subpack. that way, when it comes to parallel the 2 sub packs via the balance leads, if the #'s dont match up, you know you're doing something wrong.
If you're still unsure of yourself, use a thin peice of wire (like, as thin as your hair) to test the connection before you actually connect it with the normal plugs. if somethings wrong, the thin wire will vaporise/spark but your packs and their leads will be unharmed.
2.
are you using bullet connectors? (ie 4mm?) if yes, I wouldn't worry too much. bullet connectors manage that spark pretty well, since it'll be right on the tip of the connector, and the main current path is through the sides. Still, if you have the time its worth it, its better for the controller's internals and means you're connectors will last longer... a 100-500 ohm 3 or 5w resistor should be enough.
as to the packs order again...
ideally, you want to measure the capacity and internal resistance of each individual pack in your collection (any decent lipo charger should be able to do this). then match them up as best you can weakest with the strongest, and working in form there. that way, you end up with a pack consisting of cells that are all, on average, fairly equal. this step isn't totally necessary, just helpful for getting the most out of your pack, and reducing the frequency of balancing.
