DrkAngel
1 GW
Hillhater said:16hp - 10kwh, seems to be about the proper power range.
possibly , but you notice that the 16hp gen set you originally pointed to was actually rated as 10kw "peak" and 8kw continuous.
Also it quoted "10hrs run time at 50% capacity" with a 8.3 gal fuel tank. Presumably representing its max efficiency ?
So, if you believe that that 50% represents 4kw continuous running, and maybe that 4kw could maintain a road speed of 40mph (??)... then that would represent range of 400+ miles....but at a fuel consumption of about 50mpg
( remembering that at 4kw you are not going to be able to recharge your battery's whilst maintaining 40mph)
I guess i fail to see the point, since there are many ICE cars that can better that 50 mpg whilst giving a much higher performance than a steady 40mph !
I'll try to make an alternate view, based on your figures - estimates.
I think my offering falls within your parameters.
E Mini w/35kwh battery
65mph = 7.5kwh usage?
3.5kwh for 10 hours - car battery
4kwh for 10 hours - Generator "idling" at 50%
equals ... 650 miles non-stop
650 miles / 8.3 gal gas = 78.3 "mpg" (plus initial charge)
My original premise was that a generator could be used to greatly extend the range of an eCar.
650 miles should cover one days travel for 99% of Most "trips?"? Range could be "unlimited" if you used generator at closer to "constant" capacity, and stopped for gas every 4 - 5 hours, someone might have to go to the bathroom anyhow!
Or ... run on electric @ 65 mph for 100 miles, (leaving plenty of battery for hills, passing, etc.), then engage generator at "constant" capacity, to cruise at 65 while adding some charge back to battery.
