Rahlo12
Hi everyone,
I've had my ebike (79v on HS3540) for just over a month now, and its been great fun, but one day I got a puncture and set about the laborious task of taking out all the connections to the motor to change the inner tube. I eventually hooked everything up again, and set off a few days later when everything was patched up and connected again. I rode for about 5 minutes, when suddenly the motor started to not move and just vibrate (almost as if the phase and hall sensor combination was wrong, as I remember that sort of motor movement from when I was testing combinations to find the right one.)
initially I thought it was just a slapdash connection failing, so I pedalled back home to have a look. Everything was correctly connected, but the motor still exhibited signs of having a wrong phase and halls combination, and when power is applied just vibrated. I'm not really sure what to do and am highly worried (as I can't figure out the problem).
Does this sound like a malfunction with my controller or the motor? I know this sounds crazy, but can the phase/halls combination change and should I go through testing again?
This has really puzzled me and I really don't want my ebike saga to end after only a month...
Any help would be greatly appreciated
