Hello-
I wasn't sure where to place this, but I'm having repeated failures of my connectors between my battery (in my backpack) and my Lyen 18 FET controller. I am using a 96 v pack and when the connectors are mated the arc due to the caps filling erodes
the connectors to the point where even a 75 A power pole is compromised in a couple of days--the circuit the opens under heavy throttle and must be unplugged and remated to be able to continue. And of course the amount of draw necessary to cause this decreases with each event. Does anyone know of connectors that can withstand this. My only other thought is a current limiting resistor in line while the caps charge, to be removed before proceeding. Has anyone any insights, or has anyone solved this niggling issue?
Al
Al
