Green Machine
MadRhino said:Try DuPont Teflon Multi-Use Lubricant, you'll find it at chain saws dealers. Once you try it on a bike chain, you'll never use anything else.
Thanks..Thats actually the one i am using...works pretty good but it seems to be getting washed off in the salt water so i need to reapply every other ride or so when i get wet.
At first i had bad luck with it attracting sand because wasnt wiping it off good enough after applying it.
It seems to be working ok now that i am applying it properly.
I will "stick" with that one for a while based on your recommendation. I have some others i have been experimenting with. I figured out purple royal (an affordable large can motorcycle lubricant) is exactly the same as purple extreme a highly hiped expensive little bottle bike lubricant. Its really hard to get any good information on any of the bike lubes because all the bikers swear to one brand or another. Eventually i plan to do a comparison on a bike riding on sand and beach and put it up on a web site i am developing for sandbike care called "rustychain.org".
