bandaro said:Don't suppose you could run the belt connecting the motors on the inside, as in a 50t sprocket or something with the inside hollowed out and fixed onto the outside of the motor can, so the belt would be enclosed in the frame itself?
Would this be feasible or put too much force onto the can? heat be an issue?
I've been trying that too, I don't have enough space between the motor. I even tried to design a set up where the can itself had gears attached, but no dice
But the idea is good, the problem is that I was too greedy with the idea of building a narrow and small frame. No room for anything
