I can't find anything on this and hope you guys can help.
I think I need a 24" front wheel with an electric hub that is in constant regen mode till you activate the throttle.
Preferable around 500w and 24 to 26 volts. If you can recommend a battery tech that can handle the constant over charging, and if not, I can put in a simple switch.
I have a 24" 1985 BMX Cruiser with a 35 CC Honda engine on a belt drive to rear wheel and a portion of my commute is in a Texas park where I can't run the engine. I won't be plugging the batteries in ever so any charge would have to be gained by the forward motion. The Texas Park part of the commute is about 4 miles which saves me about 20 miles, so the batteries don't have to be much capacity, maybe even 4AH. I was thinking Lipoly Radio Control Hobby batteries in series, but not sure they are safe under regen.
