chris_kline said:45mm nozzle, 76 diameter prop, with 70mm pitch
how about your water inlet ? My prop is 60mm. This could be too small
chris_kline said:inlet is equivalent to about 80mm diameter.
i think the 60mm prop should be fine, whats the pitch of it?
just reduce the nozzle size to get more thrust, it will make a huge diference.
4kw @ 10000 rpm is very low power for that rpm. mine consumes about 10kw at 10'000rpm
ive found, going over 14000 rpm tends to cavitate on both my boards
FlorianAirs said:Hello,
I am from Germany and Reparing old Lampuga Air and Boost, if you have problems or questions just contact me :wink:
also building a electric surfboard myself with tp power 100/105 and vesc 75/300.
aethyr said:Florian,
Can you post larger pictures of the boost internals? The small pics are kind of hard to see the details![]()
Bazaki said:No. Too small
fabianpusch said:Hey at all
Today I have reached 23 MPH....was a good run in the early morning.
I have promised to send some pics...but how can I do that from my Android mobile?
Bye Fabian
PS the mhz 64 is a good choice
Your skills are madness!!! You really have all the tools to make Sh## happen.chris_kline said:hit 75 kmph yesterday!
heres a video doing not quite full speed around 65kmph
https://youtu.be/BENxS1iLGjk
fabianpusch said:https://youtu.be/hzqdDyQC6nw
Greetings from Corsica.
Your petrol powered board is amazing....really fast. Great job...and a perfect lake with best conditions. Where is it?
