karma
all ready for my high speed test tonight. i pray its not windy
http://www.youtube.com/watch?v=7HMNzOovILI
karma said:ok i ran the last test. sustained speed was 57.82mph. at 70v 28amps with a old goldenmotor.
It's very possible I'm missing something here but since it's AC that's being switched then the 3PDT relay wouldn't need to be that hefty to work well for most systems up to say 50A, would it? I agree a soild state solution would be great.GGoodrum said:Regardless of the actual speed, that point getting lost here is it works!.![]()
What we need now is for the clever EEs here to tell us how we might be able to create an electronic version of Doc's massive contactor. :wink:
-- Gary
Doctorbass said:Great news!
Update 10 april 2009
Yesterday, after few hours of hard work, i finally tested it!! ON A BIKE... ON A ROAD
DELTA is AMAZING..but i had problem with the controller that dont want to go high current
But I suspect that this problem is independent to the delta star mode add-on.
First, what i have to say: Switching to delta mode is EXACTLY like a TURBO mode![]()
It's like shifting gear but without the mecanical loss !!
It was Really amazing!!!
I started with 2 of my 4 packs of Konions for a total of 44.4V nominal and 50.4V ffresh of the charger (23Ah)
The total bike weight was around 60lbs (i used my old TREK 970)
I used one ecrazyman controller 12 mosfets that i upgraded to 4110 and all mod it must be done on that controller for high current.
I did a quick ride of around 7km to enjoy.. ( it was cold yesterday night... around 0 degree C)
With the max current problem on the controller the max speed was 33 kph and in STARS....and 56kph in DELTA at 23A on flat.. not as fast as i though with thatr controller problem... but the speed ration is still impressive!!
Having this low current problem on the controller, strangely, the most of the fun i had was in DELTA mode!! acceleration was faster from around 10kmg to max speed in that mode than in the STAR normal mode..![]()
One thing that was strange is that i felt that as the controller warm up, as the current limit decreased to around 37A max..
On the first quick accceleration from a dead stop, the peak amy showed 52A... only for the first 15sec i rided the bike... and then droped strangely to 37A max and i was never able to get back to higher current... the battery voltage only dropped a little bit to around 48.5V..... I think it is impossible that the shunt would have heat up and creating error on the curent limit.. the shunt is very similar to the clyte that i have no problem with up to 90A...
When i started the ride, i did a quick test to ensure that the controller would not blow cause i had not tested the new current limit with the added shunt i installed.
So the max power i was able to acheive with that controller was 1850W..and strangely when i go up hill, the max power at WOT was around 1100W
Conclusion.. since the controller seems to have a problem to reach max power, i can not establish true speed results from now...
What is the most important is that we know now that it work great and that the torque it still have in DELTA is enough to create a remarquable speed increase!!
I'll fix the controller and do some more tests![]()
Also.
johnrobholmes said:The windings are SMOKED, no saving them.
