I think of build my own charger out of some Meanwell HLG LED power supply units.
The HLG series does have good CC/CV limiting like a common charger, so no modification must be done at this point.
Two of the new HLG-600 (they should be soon on the market) would give a great (fanless
) 1200W charger for up to 112volts -> this is what i plan to built.
If a single supply is used, many of the HLG can be set up to 56V.
HLG-320: http://www.meanwell.com/search/hlg-320h/default.htm
HLG-600: http://www.meanwell.com/search/HLG-600H/default.htm
to convert them to a real charger, there are mainly followings things to add:
- some kind of electronics which is able to drive a relais to cut the connection to the battery
for example: if current falls below a given value (this value should be alterable) the connection will be cut
- when some of them connected in series, there must be a diode installed between every charger to prevent them from to high voltage.
i think the diode must be rated for the current.
i found this:
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=40434
this display electronics is nice, but can it be modded to drive a relais?
if not, i think of building my own electronic with arduino to drive the relais. maybe its better to feed the display and arduino board with an very small extra supply and also cut off the charger supplies with their remote signal.
what do you say?
every help is greatly appreciated
i found this:
what do you say?
