heathyoung
The diodes are across each supply - their purpose is to save the output capacitors in the power supplies if one goes into protection mode (e.g. thermal cut-off) - they stop the entire pack voltage from going across the capacitors of the supply that's 'off'. If you didn't have this, you will blow the caps.
You only need this if you are putting the chargers in series to charge (ie you charge direct to 16S). If you had one charger hooked up to half of one pack, and the other across the other half, you don't need the diodes.
I have an extra diode in series with the output, purely because I leave the chargers hooked up 24/7 (its in a large motorcycle) - if you disconnect, you don't need this.
I prefer to charge in series because I have a CA that's powered all the time, and a battery shunt, and I can see the charge as regeneration.
