supergadgetman
🧲 New user
- Joined
- Oct 1, 2013
- Messages
- 5
Hello all,
Its been a while since I posted, but hoping I could pick your ebike brains. I have an 3000W enduro frame ebike with a 72v 70amp DC Moto Controller paired to SW900 screen. I have a 72V 26Ah battery and a GEL 3000W 72 volt hub motor
Here's the problem. The bike charges fine and reads about 83V after a full charge. I take the bike out and its good for about 4 miles of using 1/2 to 3/4 throttle. Then the power just shuts down. I go to turn the controller back on with the screen and it just flashes on then back off as if I had a dead battery. I only have 300 miles on this bike, but I just figured the battery was needing replacement or it was sagging and triggering the LVC. After charging the battery overnight I decided to connect a volt meter to the charge port on the bike frame then taped it to the bike and took it for another ride. Before my ride the battery measured 82.7 volts. During my ride under heavy load I saw no major sag in the battery voltage according to my volt meter. It went down maybe .5 to 1 volt under load. I was holding steady at 80 volts then the bike just powers off about 3 miles into my ride. I look at the volt meter and it is reading 20 volts. I peddle the bike a few hundred feet to my house and park it. I'm still looking at the volt meter and its steady rising about .10 volts every second. The reading finally rests at 43.5 volts after about 10 minutes. Of course the bike wont even power on with that voltage.
Now here's the kicker. I open the frame and unplug the battery from the controller and the voltage on the meter jumps back up to 80 volts! I connect the battery back to the controller and power the bike back up and it comes right on. Still measuring 80 volts so I pick up the back tire and give it full throttle. It stays powered on only dips to 79.8 full throttle no load.
I have the controller out and upon inspection I see no visible wire damage or signs of electrical failure. I do not know at this point if it is the battery, bms, or contoller causing this issue. I do not want to rip open this soft pack testing cells if it's not the problem cause the battery seems fine. It's almost as if the controller is shutting the battery off and limiting its voltage, but when it's unplugged from the controller it resets. Has anyone ever seen this behavior. Would love to get pointed in the right direction.
TIA
TIA
