gmouchawar
- Joined
- Mar 28, 2008
- Messages
- 105
Here are some interesting numbers from Design News magazine cover from 04.28.08
Lead Acid battery 50 W-hr/kg
Lithium Ion 150 W-hr/kg
Gasoline 12,722 W-hr/kg
Lithium is better than SLA by 3x but doesn't come close to the energy trapped in Gasoline.
Even if you consider that electric motors are 80% efficient and ICE is 25% efficient the spread is large.
Perhaps this should lower the expectation of a pure electric 400 Mi per charge electric car.
a 25 MPG car consumes ~4lbs (1 gallon) to go 25Miles. At 25% efficiency that is still 12,722 W-hr as useful work and 3 times that thrown away as heat.
To do that with an electric car you need ~100 kg of Li battery, assuming 84% efficiency.
Still batteries are good for ebikes. 3kg or 6 lb Li battery is good for 1 hr of 450 W.
On my EV Global ebike that is ~11 Miles on flats with battery alone. It takes 9kg or 18 lbs to do the same with SLAs.
