Hi, it's my first post here as a registered memeber, even if i've been lurking for a while
setup :
battery : 72v 45 ah ( panasonic 21700 cells, 20s9p) BMS brand unknown, i know it's 100 amps though.
controllers : two 72v/50a 12 mosfets controllers ( those https://fr.aliexpress.com/item/1005001692282834.html?spm=a2g0s.9042311.0.0.c5006c37X7XFib)
motors: two 4000w ( peak i guess, can't find a lot of info on them ) hub motors, on 13 inch tubeless tyres.
i'm having a weird issue that i didn't experience with my last Escooter that had the same specs.
at full battery, the acceleration is actualy insane and the max speed around 75 kph ( idk if that's right for this setup)
now the thing is, i know that as the battery voltage deacreses , less current can be pushed which will decrease acceleration / max speed a bit. that's what i experience until about 73-70 volts IDLE i'd say, but then i get an extremely hard drop in both max speed and acceleration. the acceleration is reduced by a factor of 3 i'd say, and the max speed drops to around 45/50 kph and keep
dropping fast the more i use the battery.
i feel like at this voltage there should be more than enough juice to keep both motors active. in fact that was the case on my last one, the "low battery eco mode" was only activated at something like 3.1v per cell.
maybe it's a controller configuration ? i'm not surre, but it's really anoying.
any ideas ? things i could do to pinpoint the problem ?
edit : posted an update below
setup :
