Hello!
I've recently installed an eRider T9 on my conversion ebike and I've been having issues trying to make the torque assist mode work in CA3 with it.
This image shows that the CA3 does appear to be reading the torque levels properly; however no matter what I tweak in other settings I can't get it the torque response to trigger the motor assist when pedalling.
This CA3 unit was working fine with a basic PAS unit beforehand and the throttle output still works fine so I don't believe this is a CA3 or controller hardware related issue. The only unorthodox thing about the current configuration is that the eRider is being powered by an external buck converter since that's what Grin recommends for 72 V setups.
Here's my current config on the CA3:
Are there any obvious config errors I'm not seeing or anything I should tweak?
Any help with this issue would be much appreciated! :thumb:
![V3CA_Screen11[1].jpg V3CA_Screen11[1].jpg](https://endless-sphere.com/sphere/data/attachments/187/187118-a1be394c116291e9fe803fbfd282a512.jpg)
