Using a Q100C rear motor and a shark battery with a built-in sinewave controller, I’ve run into a spot of bother lately with one of my two identical bikes.
It runs for 6-10km then stops, flashing error code 03 which appears to have something to do with the hall sensor or something.
If I let it cool down a bit I can start it again and limp home ever so softly, but the error returns with every run after those 6-10km’s.
Owning another, identical bike, I swapped around literally every electrical component but without any luck. It appeared to be the motor that was at fault, so I went ahead and got a replacement.
Problem is, the error has transpired AGAIN after the bike having run well for a month or so with the new motor.
How can this be? Can there be some issue with the controller that wears the motor out somehow, or am I missing something? Every setting and component is the same as my other bike I’ve been riding every day for the past 4 years.
I’m at a loss, as you might well imagine.
Thanks for your response.
