mrwonderfull
🧲 New user
Maybe some one encountered this issue with the speed sensor. The speed sensor is in the hub. The torque sensor only works with a lot of pressure and meager assist. Throttle works fine. The three motor hall sensors light up on the tester.
How would I test the voltage on the white speed sensor on the PCB and what would be the correct voltage.
Controller is sealed.
Any help would be appreciated.
Thank you.
Thank you.
