Farfle
pkirkll said:Maybe we could get one kudo just for entering??????
At least one kudo for entering a legit torque number, that takes a bit of dedication to find.
Miles said:Steady on.... We don't want to devalue the kudo...![]()
Miles said:Let's try with the example I gave.
1.2 kg motor needs to output 3.9 Nm
2.4 kg motor needs to achieve 2.4 * 0.2 + 3 = 3.48 Nm/kg
This requires 3.48 * 2.4 = 8.35 Nm
What's wrong with that?
Miles said:Of course, you could dispute the level of advantage we've allowed for....
how many peoplle have ever build a motor from scratch ?Miles said:As we also have the three weight classes, now, I think it would be quite sensible to start with a low value for the multiplier.
Any objections to: 3 + 0.1 x motor weight in kg, for the specific torque in Nm/kg ?
Anyway, it's all a bit academic, at the moment....![]()
YouLebowski said:how many peoplle have ever build a motor from scratch ?
Miles said:Using 3 + 0.1 * motor wt. you'd need to be able to sustain 4.5 Nm/kg continuously.
Using 3 + 0.2 * motor wt. you'd need to be able to sustain 6 Nm/kg continuously.
Considering that your motor is far from being optimised for weight ...............
Miles said:So, shall we start off with the 0.1 multiplier, then?![]()
Miles said:It's the base number that we'll be increasing to "raise the bar". The weight multiplier factor will be adjusted to smooth the transition between the weight groups. So, it's more related to addressing the advantage of scale.
