Escooter 350w motor - 36v 12A controler er - shunt mod
Smobydick
Hello,
My escooter need more torque to climb streets.
I find out a cheap mod can be done to increase torque by adding shunt to the controler.
I disassembled my controler, i find something which look like a shunt.
Can you tell me if i'm correct ?
I need to cut a 2.7'' wire and add a shunt to the actual to the power black wire ?
I think the shunt is at the bottom right
Bottom left
Thank you
Yes, right place to bypass the shunt, because you don't want to be the last to taste magic smoke !
Burn them all ! :mrgreen:
Smobydick said:
Just tell me you don't want to help, or don't reply....
Sorry, yes you can add a tiny copper link to bypass this shunt. Then try if power is increasing. After the test add some solder around the copper.
Be carefull to check the fets temp, they may burn while climbing.
