Escooter Controller 36v for "Speedway Mini 3" scooter brand "
kamus
Hi guru,
My Escooter Controller 36v for "Speedway Mini 3" scooter brand "Annoy Bike" with a throttle display. It works fine. The problem is that the way the thottle twists is in a deverse manner. When I twist the throottle, the wheel running become slow, but it is fast when I release the twister.
Pic. Throttle unit
Pic controller unit
Pic wiring both unit
The controller voltage specifications:
Cable no: 1 3 wires blue green yellow to motor
Cables no:2 to 2 wires black and red to battery
Cables no:3 to display meter and throttle consists 6 wires include the followings in pairs:
1. Yellow output 37volts
2. Orange output 37volts
3. Black output 38,1volts
4. Green output 38,5volts
5. Blue output 38,1volts
6. Red
Cables no:4 consists 2 wires= 37volts
Cables no:5 consists 2 wires= 37volts
Cable no:6 consists 2 wires =0 volt
Cable no: 7 consist 1 wire
Cables no: 8 consists 1 wire
Cables no: 9 consists 1 wire
The issue here is the cable no:3 (display meter and throttle) work in reverse manner. I need help to solve this problem. My question is that whether I can shift the cables in reverse order, so that it suppose to work in the right manner. For example, I change the cable no:3 order like the followings:
1. Green output 38,5 volts
2. Blue output 38,1 volts
3. Black output 38,1 volts
4. Orange output 37 volts
5. Yellow output 37 volts
6. Red
Thank you in advance for any ideas
Regards,
KamusView attachment 1
