PJD said:
At this stage, can you just go to a different part with/or a heat sink, and get something out?
Some of us have a $3000 investment in cells waiting on this.
Yesterday and last nght I dd several tests with the board modified to remove the regulator parts (the zener, the KSC1009 and a resistor, plus the .1uF "feedback" cap and its 820 ohm resistor...), and instead simply tap off of the 4th cell to power the FET contol logic. Bottomline: this worked great.
All the heat issues are completely gone. the FET never got abov 95F, and that was with an amient temperature of 89.5F. the gatedriver chip was 104F. When the channel LEDs are fully on, the shunt resistors got to about 150-160F, but whil in the throttling/pulsed mode, they were around 110-120F. This is with the 20 ohm/2W versions.
In the last test I did, I discharged the pack about 900mAh, and then hooked up my HP 0-60V/0-15A variable supply With the supply set to 29.7 (.1V higher than the sum of the shunt cutoff voltages which is 29.6V...), and 3A, it started out at the full 3A, with all the orange LEDs off and the main LED fully red. After about 20 minutes, or so, the first channel LED on, along with the 5th one. The current was still about 3A. After a couple minutes the current was at about 2A.. At this time the "throttling" started, and the main LED turned an orangish-yellow. LEDs 2,3 & 4 were just faintly on, but this might be related to having the 1st four cells power the FET logic. The current was still at about 2A. Within about a minute, the 8th LED came on, and the current dropped to about 1A. Within another minute, or so, the 1st was still on, the 8th still on, the 5th still on, but not as bright, and the 6th came on. Less than a minute later the 2nd one was on, but faintly, and the 7th one popped on. At this point the current was down to something less than 1/2A, and the LED was mostly green. Within two more minutes, the 2nd,3rd and 4th LEDs started to flicker. It was slow enough that you could actually see it flicker, not quite a "blink", but definitely a noticeable flicker. Within two more minutes, the flickering stopped and the LEDs were all at pretty much a uniform level of brightness, which is about 3/4 as bright as when the LED is fully on. I think this uniform brightness is what is the best indication that all the cells are as full as they are going to get. In order to make sure this was "fail-safe", I left the HP supply on for another 30 minutes, but it stayed pretty much the same, except the LEDs were a bit closer to the brightest level, but still pretty uniform.. A check of the voltages about an hour later showed all eight cells were either 3.68, 3.69 or 3.70V.
The really good news is that the new boards I just got can be used for this new "non-regulator" approach, simply by leaving off three parts, and running a jumper through the three holes where the KSC1009 was supposed to go.
Here is what the schematic looks like with this approach:
The loopback jumper is used to keep the FET logic from being powered, until the charger is plugged in. I used four Anderson PP, two for the charger + and =, and two for the loopback jumper.
Today my plan is to fully populate a 16-channel board, using the 15 ohm shunt resistors, and do a heat check. I'm also switching to using 2k resistors for the main LED, instead of the 820 ohm versions I have on my test board. This should reduce the current that the FET control logic uses, which may, or may not make a difference in how much "extra" time the first four channels take,in relation to the others. Right now it is about 2 minutes, near as I can tell, and that is with the 20 ohm shunt resistors. Using the 15 ohm versions will boost the shunt current up to about 250-300mA, so that change alone will cut that two minutes in half, maybe more.
hile I build this new board up, I'll take some pics for the instructions, which I still need to do. At that point, I think I'm done.
I have boards, and I have all the parts.
-- Gary
