icecube57
Is it possible to wire an extra resistor with a switch parallel across the input resistor slots to lower the resistance to allow more current to flow through the MCU at lower voltages. I current have a Infineon XC846 72V 45 Amp Controller that workes between a programmed LVC of 58v-100v. The input resistors are to high to allow enough current under load at lower voltages I understand if this mod is possible I would have to lower the programmed lvc of the controller to a new number. I want to be able to run a 36-48v pack with a new lvc of about 29v.
I always run 88v nominal. There are times I just wanna take it down a notch. I have 6 Bosch packs that I run at 3 parallel and 2 series 74v nominal 6.6AH. I have a 12v 15AH ping booster pack. For a voltage of 88v nominal. This gives me 516wh to use.
I want to be able to put my bosch packs in a 6 parallel config and wire my ping booster in series for a solid 48v 13.2AH setup. But this will also increase my 602w. I could theoretically extend my range 5-10 miles. Depending on how I ride.
Could this be an alternative solution to knuckles any voltage mod or is the a FAILED wet dream.
